1. lazyroby
  4. Thursday, 20 January 2022
on my Emani template my cookieconsent tool cookiebot.com found 11 layerslideshow cookies. Is this necessary or can I change something on my template or module setup? You can find all cookies via "Datenschutz" at the footer menu.
Thank! Robert
  1. https://tinyurl.com/4p7jafya
Our LayerSlideshow module should not be setting any cookies. It does store some values in localStorage however. If you would like us to disable this storage, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will create the module override for you. For our reference please paste a link to this post in your email.
Thank you! Since I have some other pages and test sites as well: Could you post here or mail to me the solution how to disable the local storage of the module? Robert
Hi Robert
Firstly create an override for your LayerSlideshow module. Within that override located the following declaration...
$document->addScriptDeclaration('
document.addEventListener("DOMContentLoaded", function() {
var slider = tns({
container: "#layerslideshow'.$j51_moduleid.'",
mode: "gallery",
items: 1,
slideBy: "page",
controls: true,
autoplay: '.$autoplay.',
autoplayTimeout: '.$autoplaySpeed.',
speed: '.$speed.',
controlsContainer: "#layerslideshow'.$j51_moduleid.'-controls",
autoplayButton: "#layerslideshow'.$j51_moduleid.'-play",
navContainer: "#layerslideshow'.$j51_moduleid.'-nav",
And replace with the following, adding the useLocalStorage key and setting it to false (http://ganlanyuan.github.io/tiny-slider/#options)
var slider = tns({
mode: "gallery",
items: 1,
slideBy: "page",
controls: true,
speed: '.$speed.',
useLocalStorage: false
Note that you will have to repeat this process for any module using the tiny slider package (eg testimonials, any module with a carousel effect).
It is also worth noting that Joomla does set its own cookies for user management.
