1. webneus
  4. Saturday, 14 September 2024
I have install NINA J5, I can't make any changes to the front. I get the following error message.
0 Ongeldige controller class genaamd: config.display.modules
If I want to change an article from the homepage I get a 500 error.
http://www.traiteurzevenaar.nl website is offline now, Ciaran can u check when i send you login?
Maikel
Its a joomla error not template. Its seems (normally) that you have an non J5 extension installed.
Hi FrancW,
I install a demo package from Joomla51, no install off other extentions.
Maikel
Hi Maikel
I send you few days ago a mail with acces.
Maikel
Thanks, problem solved now!
Maikel
