1. david@torrens.me.uk
  3. Sunday, 20 November 2016
Try going to the "Welcome" menu item from.
http://whitchurchchamberoftrade.co.uk/temdem/
Note just under the menu strip the line starting "estibulum volutpat ..."
This is higher on the screen than it should be - the bookmark should be below the menu.
I know I raised this issue before - for Caitlin - maybe its not fixable - but in this case we have a link, in the template demo, to an article.
I feel it may be worth another look. No need for access to my site needed as this will be the same issue with the demo just insert this html at the start of any article mid page.
<p><a name="bookmarkname"></a>(Welcome bookmark)</p>
then link to it with ...... #bookmarkname
from the menu or an article the same page.
Hi David
Try linking to #main instead.
That does not fix the problem of the menu over-writing the location of a bookmak that you link to.
The only way is to link to above the place you want so on http://whitchurchchamberoftrade.co.uk the "about" and "contact" bookmarks are at the end of the item above.
