Apologies, I should have been more specific. I believe you have a number of different template styles for the Kinvara template, one of which is specifically for the homepage. In other words, do font awesome icons display if the module is set to the homepage? And what class are you using for your icon?
Yes, I use four different styles all named J51_Kinvara - xx. I see you only made changes to one of them, and that wasn't the one where the issue arose with the module.
#1 I copied the css codes to all other template styles. The Social Media icons set in those styles now work, however the background color for the custom icons only shows when the mouse is on the icon (mouseover) and otherwise it's transparent. Due to my white background you cannot see the icon, when the font is white and it looks aweful if you chose any other font color because of the blue colors of Facebook and insta.
#2 I canged the icons of the icon module to font awesome and used the links provided on their page (which work for the social media icons) and I get these erroc icons again.
The Kinvara Template I have is from last year. I now downloaded the newest version and will overwrite the files on my webspace. Maybe that'll help ... unfortunately it did not:
https://buchpassion.com/index.php/de/medien
