1. ziggy
  4. Friday, 07 June 2013
hey guys..
i recently bought the j51 nocturne theme and now i have a question
is it possible to make a line break inside the mainmenu ?
the other question:
how can i put the login box into a dropdown menu ?
http://www.actionsystems.eu/
this is the site..
i've got the following problem:
i got a mainmenu link like:
PROJEKT SUPPORT
but i want it like this:
PROJEKT
SUPPORT
centered
any advice you can give me ?
maybe there is an option to limit the width of the table to force a linebreak?
To achieve this style of menu you will need to use a 'mega menu' styled dropdown which allows you to add multiple modules in your menu dropdown. Sorry to say this feature is not available within this template however there is a number of mega menu extensions available. One option may be the following however it has never been tested with this template...
http://extensions.joomla.org/extensions/structure-a-navigation/menu-systems/drop-a-tab-menus/18101
To wrap your menu item to a second line try adding the following to the Custom CSS field of your templates parameters...
[code type=css]#hornav .item-107 a {
padding: 5px 15px;
white-space: normal;
width: 65px;
}[/code]
thx.. it worked great so far :)
so i've got another few questions to bug you:
if you could take a short look on our site:
you will see that the SideCol-A and SideCol-B doesnt fit in width when its shown on smaller devices (iphone/etc.).. the width is set to 25%
another problem is that we set the sidecolumns to show an image (like on your live demo)
but the text is inside the image :(
would be very nice if you could help us :)
thx for your nice support,
greets coldi
Hi Coldi
Just to confirm regarding the width issue, you would like the sidecolumns to remain at 25% on smaller screen devices?
For the icons in the sidecolumn area try removing the following from your templates nexus.css (../templates/j51_nocturne/nexus.css - line640)
[code type=css].sidecol_block h3 {
padding:0px 0px 5px !important;
}[/code]
hmm..
sry for my rly bad english :/
no i would not like to remain the sidecolumns ab 25% on smaller screens..
i attached a picture below.. there are about 20px or something difference to the right border from sidecol-a and sidecol-b
http://www.image-upload.net/di/TE8Z/Bildschirmfoto_2013-06-14_um_17.png
Thank you for clarifying.
To amend try adding the following to the Custom CSS field of your tempaltes parameters...
[code type=css]@media only screen and (min-width: 768px) and (max-width: 959px) {
#sidecol_a .sidecol_block {padding:0;}}
@media only screen and ( max-width: 767px ) {
#sidecol_a .sidecol_block {padding:0;}}[/code]
