Dear,
Since the last Joomla update it seems like the Chelsea template has a few issues with the pictuer selection tool. For example if I go in the settings of the template to add or remove pictures of the slideshow, I only have one button left with three dots and it's not working. I used to have multiple buttons to add, remove or move a picture.
There's the same problem in all the modules that come with the template. Is there a fix for this issue ? Thank you.
Best Regards,
Peter
